So update to the original post.
I received my micro-mesh pads today. I wet sanded the car body with 3600, 4000, 6000, 8000, and 12000 grit pads. The followed that up with a nail buffer. Actually ended up with a decent finish. Though it's hard to get in to some of the details with those. Definitely smoothed things out and got a much nicer finish! Unfortunately a couple of the edges got taken back down to styrene in the exercise.
Last night I laid down some coats of the gloss black acrylic on a chuck of styrene sheet I had laying around. Going with much multiple passes of much thinner coats seems to be getting better results as well. So with that lesson learned, I'll build up a couple of more thin coats on this model to get to a final finish.
All in all I think this is going to work out. So some lessons learned here (Which was why I built this car in the first place!)
- Bad paint jobs can be recovered with wet sanding or if it's horrid, out right stripping
- Lots of thin coats with acrylic are better (rattle cans I can get a nice finish in three to four coats)
- It's less effort to get the paint job right in the first place!
