Well when you're brush-painting, it's not so much of an issue as the fumes from an open paintpot are small (as long as you don't put your nose down there & inhale!) The issue is more about the use of an airbrush & specifically the way the paint & thinner mix with the air into fine droplets. Also, there's much more of the stuff around when airbrushing.
Think of it like dabbing on a bit of aftershave before you go out, compared to choking when the missus squirts her perfume all over the place!
Patrick
Patrick
