Airfix 1/24 hurricane
peterairfix
I have been itching to have another go at one of these it's not going to be my usual out box build as I will having a go putting in wear and tear and something I don't normally do witch is pre shading here's the results on engine and one side of the rear bulkhead.
And the wing underside IMG_20211022_104333.jpgIMG_20211022_103701.jpgIMG_20211022_103528.jpg
Engine and bulkhead finished not to sure on the color of the exhaust and cockpit started. IMG_20211023_124236.jpgIMG_20211023_124222.jpgIMG_20211022_171808.jpgIMG_20211023_124424.jpg
All the cockpit frames are painted weathered and ready to be assembled and I finally have a use for my seat belts that is all the extras I will be using the rest of the kit is out of the box. IMG_20211024_092854.jpg
Whilst waiting for my magazines to arrive I have done some more on this build.
I have squeezed the engine and cockpit in fuselage halves and started the weapons bay. IMG_20211030_151000.jpgIMG_20211030_150946.jpgIMG_20211030_150924.jpgIMG_20211030_150915.jpgIMG_20211030_150757.jpgIMG_20211030_150749.jpgIMG_20211030_150743.jpg
Finally I can now carry on with this build and I have preshaded the new wing section and the two upper halve and installed the weapons bay. IMG_20211120_130053.jpgIMG_20211120_130039.jpgIMG_20211120_130036.jpgIMG_20211120_130042.jpg
Peter
That's turned out very nicely indeed, always good to see the camo on.
Very well done.
Just noticed something on the decal instructions the top view the navigation lights are in the right place but when it's flipped over they seem to have magically changed sides so l had to check because I was about to remove them and swap them over good job I didn't. IMG_20211123_095901.jpgIMG_20211123_095907.jpg
