Well I did promise that when I got it I would do an in box review, so here goes.
First the box is big, even for a 1/48 scale aircraft. In fact if you have one or have seen one its the same size as the Buccaneer, also by Airfix.
The box contains three large sprues in the fashionable light grey plastic. One small sprue for the clear parts. Lets get that out the way first. The canopy is thinner than others I have seen in this scale and should look great even without the Klear treatment. It is also a nice clean cast.
The three large sprues are two for the actual aircraft and one for weapons mainly, with a few smaller parts from the airframe. There are TWO wheel sets, weighted and none-weighted, which is a nice touch.
To help you stick it all together is a 23 page A4 booklet, with clear step by step drawings which are very clear and well thought out. As per norm there is a choice to be made as to which of the four versions you wise to model and this must be decided on quite early in the build and the instructions would benefit from a marker/high-lighter to aid with keeping track of the version you wish to build.
There is even a colour guild, in colour for the four versions. Pitty they are all grey/white but better that than the normal ten shades of grey print to try and figuer things out.
The decal sheet is printed by Cartograf and the quality is as can be expected from them!!! Nice! I bet there is not to many moons gone down before some one does the Red Bull Decals for this!!! Imagine that bird.
When I get a round to building this I will try and update this a bit with my findings along the way.
But as it is now I will boldly say go get yours, while you can. five stars from me,
View attachment 22726View attachment 22722View attachment 22721View attachment 22727View attachment 22723View attachment 22719View attachment 22718View attachment 22716
A closer look at things show the level of detail to be acceptable, and those that want to add or improve will find things to improve. The Panel lines on the wings/fuselage are not over done and by the time there is primer, paint, klear and a dull coat in them they should be even better.
