Airfix 1/72 Blackburn Buccaneer S.2C
Those clever bods at English Electric didn't bother with wing fences or vortex generators for the Lightning, they put a notch at two thirds span on the leading edge, very clever! Take a bow Ray Creasey!
Miko (not as streamlined as I used to be)
THANKS Miko as i often wondered what the notch was for in a lightning wing leading edge now i know you sir are an inspireation to me
chrisb
chrisb
Also the location of the wing fuel tank vents
Miko (perhaps should apologise for hijacking this inspiring Bucc build thread!)
Lovely work thus far, and a very interesting discussion on the Vortex Generators.
Just a word of caution with this kit, I found on mine that the wing-fold isn't very strong. I've noticed over time that my wings have collapsed in on themselves slightly until the tips started to touch. I mean, Okay, I did build mine as a D and hung Martels from them, but just a warning none the less.
Sorry for the late reply. Thanks for all you posts. My dad would have really enjoyed the discussion on the wing fence thingies. When he worked on the Buccaneer design team his area of special expertise was in fluid dynamics which I believe is all to do with airflow, lift etc.
Anyway despite time being tight, the dreaded DIY as "suggested" by SWMBO and my daughter having 'some little jobs' lined up for dad, I have finished the build. I have fitted the wheels although I would have preferred to leave them until after painting. Unfortunately the fitting of the wheels was very fiddly, although the fit was good, and I knew that I would not be able to fit the wheels later without damaging the paint work. The undercarriage doors will be fitted later.
The temperature is forecast to cool a little over the next few days so I should be able to get some primer airbrushed.
Thanks again for your support and again sorry for not acknowledging it earlier.
I know the square root of naff all about aero dynamics or wing fences but I do know a good build when I see one mate.
Bet you know more now. We'll have you taking flying lessons soon Paul!!!!
Cracking work Jim, really looking good. Iconic NAVAL;) aircraft your doing a fantastic job of replicating!!
I'm so sorry, Jigs, uuhhh Jim, that I totally missed your build. I must say, you are up to your usual fine quality building skills Sir, and on such a tiny wing thingy kit too. Very nice Jim and I hope it cools off so you can shoot some primer. The heat is holding up a bunch of us...
Is it me, or does anybody else on the forum hear the theme song from the TV series "Flipper" playing in the background??? Must be the Bucc's tail fin causing it...
Allen
Just out of interest Jim, does the kit show/have the tiny little vortex generators on the upper leading edges of the wings? When working on them in training I always they always drew blood when scrabbling over the wings. (Never got to work on the aircraft after training).
It's coming on a treat, even 'naked' it looks every bit a Bucc!!!
Yes. But you have to remove one or some (I can’t remember the exact number) depending on the mark you are building. I learned this when I did mine as an early 12 sqn jet
Out of interest, Nimrod MR2’s also have wing fitted vortex generators.
Thanks guys for your nice posts. A little more progress.
One issue was the potential problem of this sitting tail down. The instructions call for weight in the nose. Because I have made the nose cone folded I couldn't include weight as I doubt the hinge on the nose would take it. I intend to put this on a section of carrier deck (if I'm lazy it will be one from Coastal Kits) so decided that the nose wheel could be pinned to the base. I drilled and fitted a piece of wire.
The canopy was masked and fitted temporarily with tiny blobs of PVA. The wheel wells were masked and the whole lot sprayed with an MRP darkish grey.
I masked for the silver leading edges on the wings and the engine intakes. The canopy has been removed.
I used Vallejo Metal Color.
I painted the tyres and a yellow panel - don't know what it is or why it's yellow?
The FOD covers, the canopy and some other odds and sods were masked and painted.
Still a way to go but we're getting there.
Thanks again for looking in.
Good solution with the pin. I suppose you could have gotten enough weight in front of and around the cockpit to keep the nose down, but that requires a good deal of planning if you want the nose cone folded, of course.
Look very Buccaneerified now, great job, inspiring me to build mine
Really late to this Jim so apologies.
Looking well built as expected from you , like the pin in the nose wheel to hold down .
Thanks guys for the nice posts and also for sticking with it :thumb2:
Started to apply the decals. I had forgotten just how many there are on aircraft. Some of the stencils won't get used - just too small and insignificant. Maybe OK for 1/32 or even 1/48 but at 1/72 - no way. I'll use as many as I can though.
One side of the body started, the wings done top and bottom and the detonator thingy on the canopy.
