Airfix 1/72 E3
Nice, something a little different, will be watching this one
The fuselage uses (in my veiw) an un nessesarly "complex" way of engineering. You have the bottom section and the two side sections incorperating the top section.
I found it rather fiddly to allign and cement together. You have to hold it all inplace and try run cement into the seam...needless to say I got a fingerprint or two on the model doing this.
There will be some filling and sanding to be done on the fuselage seams.
Theuns
I tried to replicate the anti-corosion treatment they used on the Eindecker's sheetmetal parts.
I sprayed the cows X-11 silver and with a fine brush randomly painted streaks with humbrol "steel" that is a little darker.
Theuns
Natural doped linnen paint on, when dry I will add the shadows of the rib tapes.T
Nice start, I like the look of this little thing.
Thanx. I will most likely use EZ line for the rigging.
Theuns
The linnen coluor is to yellow and it lacks feel.
I cut 1mm wide strips of tamiya tape and mask the ribs. Then I lightly spray tamiy smoke over the rest to make it a little darker and more "dirty"
I used the same on my 1/48 Nie 11.
Theuns
A heads up to anyone building this kit. I painted the model future as a gloss decal coat today and left it in the sun to cure. When I got to it there was a marked sag in both wing pannels downwards. It is winter here so it must have been max 15-20 deg C
I had to re-enforce the wing to fuse joint with thin super glue, hoping it will keep over time as the thin joiner bar on the inside of the fise binding the wings I recon is not up to the job and the wingroot seam is so thin glue area is really small.
Theuns
Theuns
Good info Theuns, I picked one of these up a wee while ago. Maybe some sort of reinforcement is in order to prevent future wing sag/failure. Do you think a continuous rigging thread would help?
I ran thin superglue on the wingroot and it feels better. The EZ line I used for rigging will have no structural value. Maybe a thread that does not stretch will help...
Theuns
