I have just started the Airfix Stuka today with my newly bought A.B . It is AWESOME! Photos will soon follow....
Sometimes it is worth remembering that if you have a really bad joint it may be a better option to remove the locating pins and align the joint manually. Possibly align it with clamps and tape etc then apply a couple of spots of cement on the surface. When they are completely set in a day or two remove the clamps and brush liquid poly along the joint., capilliary action will take the glue into the joint The only thing you should have left to remedy is the raised spots of cement.\ said:I just put the fuselage together today which showed that the surfaces had a cliff that sanding could not remedy, so I had to use lots and lots of filler to cover it up. John
Eduard do make self adhesive PE sets.But when I used one on my TSR2 I found they didn't stick very well.So I ended up glueing them on with CA.\ said:If you have noticed in the first photo in the second posting of photos, I have scratch built an ammo belt.... Any reply on this and if anything is wrong, some constructive feedback would be appreciated. The eduard seatbelts were exceptional, yes I completely agree. Their photo etch metal was not wafer thin, nor was it overly thick. The instrument panels were also well developed. A little nice touch would be to have some parts self adhesive, but overall I would give 5***** to eduard on this product. I have been experiencing some problems in my airbrushing where the paint seems overly clear and sprays well, but too runny. Does this mean I have been using too much thinner?John
