AlanG's 1/32 Hasegawa Fw190 A8
Quick update from this morning.
Fitted the two rear armour brackets so i can get the armour adjusting wires fitted. Had a bit of a mare with the superglue so one of them is a little squint. But i can live with that. Also it was nice to see the radio wire hole looks good too.
Hi Alan
Missed this - sorry. Just had a catch up. I do like these larger scale aircraft kits. You're doing a great job. Undercarriage especially looks good. The canopy masks look a bit extra fiddly but seem to have worked nicely.
No probs Jim and thanks. Beers are in the fridge and the quality street are by the chair. Pull up a chair and share my trials and tribulations lol.
Cheers Ian. I'm enjoying adding a little extra detailing. Still loads more i could do but i have learnt that for the next one i have planned to build in the future.
Forgot to add this little detail when doing the radio cable. Although the Hasegawa rear panel is slightly wrong behind the cockpit seat (the box section is in the wrong place) i thought i'd still add it as the wire from the aerial will need somewhere to go once fitted. So it goes into a trunking tube that then goes down into the cockpit. I used a bit of copper wire to replicate this and shall re-touch up the RLM 66 later.
Cheers Ian. Not much more to go before i can finally start pre-shading. Finding time between the kids and the farm is a challenge but i wouldn't have it any other way lol
Added few little bits n bobs on today. The gunsight, RF loop and drilled out the 20mm cannon barrels. I started with a 0.45mm as a pilot drill then gradually opened the barrel up with a 0.55mm then finished off with a 0.6mm. I didn't want to risk it any further than that. Here's the barrels.
Will do a few more bits tomorrow (maybe) depending on how i feel after work lol
Evening Al,
Bit of a late comer, but enjoying the build so far. Coming on nicely :thumb2:
Cheers Si. My first model for about 4 years so it's a learning process
Well, that's 19.2mm at full size, so near enough to 20mm!
Jeez i forgot just how tedious adding the little bits (aerials, pitot and wingtip lights) is just before painting can begin. Little bits that need to be done but take an age when you're chomping at the bit to get the compressor fired up :)
But all there now. Pre-shading can finally begin
Hi Al well it looks a good build to me like the way you have run the b-pipes down the under cart leg an drilled out the gun barrels spot on work I think an bean seems to like your build v-good that looking forward to more chris
Cheers Chris. Not done anything on it this week due to work and finding a join line i missed so needs filling. Typically it's in an awkward place and my mojo has taken a bit of a hit.
Started a little pre-shading tonight. Not happy with a couple of things but hey ho. That's us modellers for you. Can't wait to actually get some proper colour on this wurger
That's the RLM 76 applied. Used Hannants Xtracrylix. Love the colours but imho they are a complete :poop: to spray. Need to start masking for the RLM 74/75 now. Bluetac at the ready!
Hi Alan
Never tried Xtra crylix paints although I like their varnish. Looks to have gone on well despite the spraying difficulties. As for pre-shades - I am too heavy handed and obliterate it with the top coat :worried:
It doesn't show through well on the pic but in the 'flesh' there is a little demarcation where the pre-shading comes through. I don't like to do it too heavy. You can always go over it post-shading with a hint of dark grey/black in the main colour.
