She's almost finished. Last coat drying then little bits like wheels, propeller and antenna go on and finally canopy masking comes off.
Some of you may have picked up I've been calling her the swearing spitting model due to the bad fitting and amount of filling and sanding needed. You may also remember some of the funny typical newby mistakes I mentioned, like the panic wiping with thinners. Have I mentioned, I was so angry that the engines didn't fit for an open display, that I cut off two exhausts on each side of the right engine to try and get the fit to work... look carefully at the pics. In the end, i dismantled the engines and display the exhausts with the engine covers closed, very bad fit that I decided not to fill to see the end result after painting compared to the bad fits that I did fill and sand.
So, pics attached, for your amusement, but I've enjoyed her and she's given me a lot of practice and I've learned a lot, which is what I wanted. Brush painting skills are getting better. Thanks for all your advice along the way where I chipped in on other threads. Will post the final pics when all the bits and bombs and guns are attached. Oh, pilot's head is a bit flat, if you're wondering. Canopy wouldn't fit otherwise, so I had to file the poor guy's had down a bit
Frikkie
Frikkie
