Amati 1\250 RMS Titanic full kit
I have now started on the boat deck structure's and here's what I shall be doing.20191230_132734.jpgAnd here are the first two pieces and the finished rudder.20191230_132755.jpgAnd the rest of the pieces waiting to be finished off but the eagled eyed amongst you will notice I have built the gym the wrong way round but at the time of this posting I will have rectified it.20191231_145639.jpg
Here's and small update and the last of the pictures while I clear the backlog of plastic kits.
All of the main deck structure's with the exception of the second class lift shaft.
And a test of all funnels in place20200109_125059.jpg20200109_125115.jpg20200109_125124.jpg
Found some time to do some more this time finishing off some of the sub assembly's ready for final detailing with the photo etch and I have substituted the paper decoration on the vents I favour of wire mesh.20200127_134451.jpg20200127_135027.jpg20200127_140947.jpg20200127_142147.jpg20200127_150537.jpg20200127_150545.jpg
More sub assemblies finished this time it's second class lift shaft and the are around the fourth funnel casing.20200129_150016.jpg20200129_150000.jpg20200130_151149.jpg20200130_164634.jpg20200130_164714.jpg
Another part of boat deck finished this is the reciprocating engine casing/tank room it also has the first class aft staircase dome with it but as I am waiting for some after market parts to arrive from minibrass it will remain empty.20200202_125920.jpg20200202_125941.jpg20200202_125947.jpg
Time for an update all the sub structure's are now attached to the boat deck and all the vents are finished and also attached.
I have the two pe domes in place all not very visible in the pictures.
And I have the third and fourth funnels in place.20200223_133108.jpg20200223_150210.jpg20200223_151129.jpg20200223_170039.jpg20200223_170050.jpg20200223_170058.jpg20200223_170105.jpg20200223_170112.jpg20200223_170118.jpg
Fabulous.
First and second funnels completed in place but not yet secured and the first two davit test pieces using my new PE Bender.20200311_075917.jpg20200311_075934.jpg20200311_083328.jpg
That looks so good Peter.
One regret I have was not lighting mine, but that is because it would hide the dreadfully amateur finish. Don't think you'll have that regret!
Time for a little diversion from plastic and for this update I have finished all the railings and fitted the stairs.20200423_195723.jpg20200423_195734.jpg20200424_172615.jpg20200424_164049.jpg20200424_134558.jpg20200424_134551.jpg
