After slogging away at the 6 models I have made so far I wanted to show them off as best as possible.
Bought contiboad shelving & slotted shelving system from who ? yes B & Q. 10% discount on Wednesday for people who are not young !
But it all looked stark & dreary. But did not want to build a complicated diorama mainly as this would take away from the aircraft models.
So decided the best way was to show them in their natural environment but simply. The pictures illustrate what I came up with. Also did not want equipment straddled about the place but at the same time wished to show the proportions of the aircraft. I introduced the minimal of figures to illustrate this. Unfortunate that those available mainly Revell are not brilliant but there you go.
After a lot of "looking" I came up with the following materials. Sky (got to redo as it has bubble should have use photo spray not PVA) ID Mock Scenes which is very realistic & on a 150 gm paper.
Grass. Very difficult to find realistic but found some which looks really good. Heki Static Grass Matt Dark Green 75cm * 100cm. Used thin PVA coat on base & brown paper backing of grass.
Runway. Used GaugeMaster Gravel Mat (railway track stuff) . 100cm *75 cm. Glued same way as Grass. You have lay as you would hang wall paper it will stretch so needs pushing out the bubbles technique. It will then dry & stretch to a good flat finish.
The labels were simply designed on Coral Draw, a publishing programme, & then printed on semi gloss photo paper.
Should add that the sky bit is being replaced & looks tatty at the moment.
