Another Spitfire
Thank you. I just hope can do the same with this model.
I glued the seat belts.
I painted the landing gear wells and glued the wings.
Interior ready.
Cut stabilizers.
Regards.
ajcmac
This is one of those models that builds quickly, quickly. We'll see when the paint will also start quickly.
Fuselage already sanded the glue marks.
Here the interiors already glued.
The wings also have ready.
And all ready to start painting.
Regards
ajcmac
A very clean build.
Good luck with the paint work.
i have never built one of these but your build is making me want one..you have done an outstanding job on the cockpit looking forward to seeing some colour on this
It's looking good so far. It does look like a good quality kit.
Thank you for your comments.
I started painting the model.
First the propeller hub.
After the bottom of the fuselage and wings. Medium Sea Grey (Tamiya XF-83).
Now the shadowing.
Regards
ajcmac
Thank you for your words.
Polux, the Spitfire Eduard Royal Class will be my Christmas present to myself.
Finished shading the lower surface.
Now put the mask to start camouflage upper surface.
Regards
ajcmac
That cockpit is fantastic and the rest is coming on great , I have no doubt that this will look awesome when completed :)
Thanks for your comments.
I painted the spinner and propeller.
The fuselage has painted with Grey Ocean Tamiya XF-82.
Regards
ajcmac
coming along very nicely,
what the trick you use for showing the under wing detail ? just a darker tone off gray to highlite the seams and
so on then a liter gray ? to blend it in, as i use a brush not an airgun let and have only done 1.72 planes but
have some 1.48 kits i got for cheap,
keep up the good work , watching your post to see how its coming along
cheers
monica and Vaughan.
Thanks for following and for your comments :) .
Ocean Grey is ready.
Now we wait until Monday (I hope) because I still do not have the Eduard masks.
Regards
ajcmac
the look of this plane is 1st class mate well worthy of 5*s,and the weathering is great
mobear
