Hi having sprayed Vallejo primer onto my model over 48 nearly 72hrs it is still soft to touch and will not feather.
Could spraying to far away cause this? This is the only variable I can think of I pretty much followed everything by the book , no thinner used airbrush cleaned and run through with thinner after.Also
Sprue cleaned wiped down ect...
Also I've tried to give another coat of primer but this shows up all the problems of none feathering , should this have self leveled and hid it?
Many thanks
Daz
Many thanks
Daz
