Any suggestions?
BarryW
My Trumpeter 1/32 Grumman Avenger build is progressing well.
The main construction is done, the model is primed and pre-shaded and tonight I will lay down the white base coat on the underside.
Allowing for a week when I will be off on a cruise in the Eastern Med the model should be finished in about 3 weeks or so - except...
I found I had an extra transparency sprue in the box but no turret transparency.
Back on the 1st April I investigated a replacement and sent off to Pocketbond all their requirments to get the part. Two weeks ago I rang them and they said a consignment was due in a week or so and the part might be in that. No news since and I will chase them again next week before I go on the cruise if it does not show.
But if this part is not forthcoming what do I do?
Has anyone any suggestions? I have heard that Trumpy are very poor in these situations and my confidence is low, its not exactly a cheap kit....
Does anyone know of an aftermarket part or how I might be able to lay my hands on a turret?
You could try Hannants Barry, I haven't personally, but I've heard they often have bits & bobs.
Could try the retailer Barry but this is grasping straws.
At least inform the retailer of the missing part. Tell him (or her) that you want a refund unless it is forth coming.
Find if the retailer has another one and then get him to raid that one.
Alternative buy a new one remove the part and then demand your money back on the new one. although this may be fraud I suppose.
\ said:
Could try the retailer Barry but this is grasping straws.At least inform the retailer of the missing part. Tell him (or her) that you want a refund unless it is forth coming.
No more fraudulent than not the retailer not supplying what one paid for. April is nearly three months ago.
I spent a wee while searching online Barry and could find no after market canopies/turrets for the 1/32 Avenger anywhere in the world. The kits are expensive! The only thing I can think of is to watch for an old model to be sold on ebay or suchlike so you can cannibalise it for the required parts. Guillows make a balsa model of the TBF in 1/32 (which would have been much cheaper) but the canopy is one piece and wouldn't be up to the required standard for your build. I'd chase up that retailer.
Thanks everyone for your suggestions. I will decide what to do when I get back from my cruise.....
