If they’re for the 15 cm sFH 18 then they’re not 18 cm, they’re the same calibre as for your 15 cm sIG 33. If the baskets are for the projectiles only, chances are they would be the same for either gun — or at least, that the sFH 18 ones won’t look out of place with an sIG 33.The other Jim has been kind enough to send me the 18cm ones so we will see how they look first.
Ooh! Ooh! I know the answer!I tried both types of Milliput to see which worked best.
My idea would be to use a different epoxy putty, one that’s easier to work with and finer-grained. If you must, the white Milliput is fine enough but very hard to tell if you’ve mixed it correctly (one part being white and the other, off-white).I am sorry to report it didn't work. The part was too small and the end snapped off. The yellow Milliput totally fell apart. However I am not defeated. I have done some more and I will leave for a couple of days.
