Shaping up nicely. Shifter looks like a 9"Hurst. Straight pins or music wire work great. Curt off the ball, drill a hole & stick on the pin. Make the appropriate bend & stick pin in hole in floor-presto, excellent shifter. PaulE
Now that I like Paul, can do that tomorrow, then going to hand paint the inside. Thanks :thumb2:.
Sorry JR, just caught up. Coming along nicely. Hope you go for the replacement wheel/tires as they look 10 times better than the box items. Cheers, Rick H.
Hi Rick, I agree, replacements in the hands of one V2 rocket expert Von Dewire. who has located some in the Fatherland.
John.
Been doing the odd bit here and there today while the tyres get ordered.
Decide to get as much of the stuff glued in groupings, I ve done some boxes, but tried with out the car body, do able but then the body would be harder to fit as they touch the body sides.
Dids add the radiator assembly, there were two options with some stays to either hold open the front maintenance doors covering the front of the rad or too have then shut. After all this time spent building the engine and rad I decided to have them open.
One set back was the holes in the brkts were tight, no way was I going to be able to enlarge then to allow some pins in , so dispensed with the plastic all together and am going to replace with some wire.
Even went as far as cross hatching the inside of the rad, don't know if it will be seem , but it did look better. :nerd:
I noticed the brkt on the right had moved irs now back in line, those were the ones I was referring too .
There was a slight misalignment with the rad and the hose, don't know why , but the next one I will fit the hose last. Hence the filler.
Right thats where I'm up too . Thanks for following and for the comments.
John.
