Hello All,
Thanks to Ian for his usual magic and setting up the thread and the inventive title which is admittedly better than ‘Migs’
So the usual rules:
Enjoy, comrades!
So the usual rules:
- Any Mig is eligible, any scheme, any variant and any build country, it does not need to be built in the Mikoyan factories, they had many built on license.
- No Diorama, just the build please.
- It can be on a stand and posed in flight or on the ground, but not part of a bigger diorama. So on a plinth with a rod is fine. Adding this rule as mine will almost certainly be done that way with a plinth, brass rod, in-flight Mig-21.
- Any scale, any form (injection moulded, 3-d printed etc).
- Kit should not be started, it can be bottom of the pile in the stash so long as it isn’t started.
- Please start a build thread for your entry, the Mig type, model brand and scale and most importantly your name.
- Start the thread with pictures of the kit, and sprues as ever, plenty of pics and updates.
- Last but not least, make it a Mig. As far as I can see from Google (other search engines are available), Mikoyan primarily focused on Fighters both prop and jet but they did make some unmanned aircraft and cruise missiles, so if you can find one, that would be just fine.
Enjoy, comrades!
