Boldman 1:35 Austin Tilly "with load"
Okay so now I've been given a clue as to how this works here goes with some box and sprue pics...
First the main subject:
View attachment 26726View attachment 26727
So I'm afraid the sprues on this one are a bit empty because construction has already begun (noob alert!)
Anyway, in order to qualify for this GB the "truck" really needs a load. So to this end here is a selection of what may OR may not appear in the back of the Tilly...
View attachment 26728View attachment 26729View attachment 26730View attachment 26731
Andrew nice start so far love the alsatian dog very nice.
scott
So this was posted previously in Under Construction...
There are 3 colour schemes shown in the instructions. I'm building the basic green colour scheme.
Starting with the chassis and engine:
View attachment 27004View attachment 27005
I haven't got involved in superdetailing, my eyesight just isn't good enough for lots of tiny wires and extra details, especially as the bonnet will be closed so the engine won't be visible. However for my own satisfaction I try to do a decent paint job in it.
Next, the chassis which has quite a bit of underbody detail:
Next comes wheels and bumpers. The wheels are only pressed on for the moment. They will need more weathering done to them:
Next is the cargo area. This will be without the tilt covering it so I will be adding the frame poles later. The wooden floorboards have been suitably weathered in preparation for the load it will carry to qualify for the Group Build ;)
View attachment 27008View attachment 27009
I've used the wooden tailgate instead of the pressed steel one.
Finally so far, tonight the seats went in and some more weathering was done on the wheel wells.
View attachment 27010View attachment 27011
You're going well there
At this rate you'll be finished before I've started mine
Since that was originally posted, of course there has been further progress...
The pickup section has been added, the frames for the absent tilt have been added using wire, steering wheel added and cab painted, which includes battery detail for under the boonet.
I will be closing the bonnet so I didn't have to paint the batteries, but you know what its like... YOU know its there even if nobody can see it :)
Next, the cab gas been added to the chassis
and the windscreen is in place.
And finally for this section, bonnet is in place and...
View attachment 27015View attachment 27014
We have a driver!
That's all for now...
\ said:
You're going well thereAt this rate you'll be finished before I've started mine
I did sort of jump the gun a bit, not fully understanding the Group Build rules I'm afraid.
Oh right, you'll have to build something else for the GB after the Tilly's finished then
Andrew, nice progress mate it's looking good so far. Is it going in a diorama?
scott
Yup it will be in a diorama... watch this space for further progress... ;)
Further progress...
So here are a few pics of the next bits of the build.
First off we have the bonnet and doors, along with headlamps doorhandles and indicators.
View attachment 27134View attachment 27133
In the background you may notice some of the cargo that will be in the back later on...
So as I said in my previous message, this WILL be a diorama and so we begin landscaping...
View attachment 27135View attachment 27136
I started with a nice and cheap 7"x9" picture frame from Wilkinson (the people who have replace Woolies in many high streets) It cost about £3 and is ideal.
I bought the wonderful book in the Osprey range Terrain Modelling by Richard Windrow and so used the technique described in there to make the tree from a wire wound armature coated with Tetrion filler. While the Tetrion is still damp you score it to a sharp point to make the tree bark texture. The white stuff is called Air Dough which I bought on my shopping trip to 4D Modelling Supplies I was enthusing about a couple of weeks ago. Its got a foamy texture to it but you can sculpt and mould it, using water to soften it. Then when it dries it has a stiff foam texture that is a little bit flexible and will easily allow things to be inserted into to to support other structures as you will see later...
You can see the card I used to support the sides and this will later be removed to allow the construction of a section through the earth.
The next stage is the roadway...
View attachment 27139View attachment 27140
You can see I've added some paint over the air dough now. It took only a couple of hours for this to dry. The roadway is made us using Claycrete which is essentially ready made papier-mache, just add water! The dust is a bit of a pest so be careful when you mix it up.
You'll also notice I've built up the Claycrete around the back of the earth sections. This is because the texture of the claycrete is almost perfect to represent an earthy type of cut.
While waiting for the Claycrete to dry, I added some support for future landscape elements...
The sticks used here are actually from a bristle scrubbing brush bought from a hardware shop. I cut off one bundle of bristles which give a nice selection of thickness of sticks.
You'll also have noticed that I put more effort into the tree. I did try adding foliage but it looked terrible! So in the end I cut of the ends of the branches and re-coated the bare metal tips with tetrion and the tree has become a dead tree. I've painted up the bark to look more realistic and I'm quite pleased with the effect...
So now its just a matter of waiting for the Claycrete to dry...
Good work so far on the diorama base. I must say that tree looks rather good. It it good to see some different "building materials" being used. Its a good chance to see what can be done with the different things available.
Andrew nice job on the tilly mate and that dios comin on a treat keep up the good work.
scott
3 days later...
So 3 days have passed since the claycrete was put down and finally it dry enough to continue!
So first up was the section through the mound. Here I used some artist acrylic paints concentrating on raw and burnt umber plus some black. I stuck some of the bristle twigs in to represent various roots and fixed some small ballast rocks in to represent, um rocks. Some of these were painted to provide some variations. The surface also got a coat of burnt umber and burnt sienna to give it a more earthy colour.
View attachment 27173View attachment 27174
So next came the trackway. This was constructed the way a track would normally be built, first with larger stones as the base with an infilling of smaller stones and gravel. In this case, three different grades of model railway ballast. Then the verges were built up with various grass flocks, pebbles, some bush foliage, sticks and static grass, along with some taller grasses made from the bristles of a wallpaper brush mixed with some scenic long grass material.
View attachment 27175View attachment 27176View attachment 27177
The hedge is made from rubberised horsehair (that name always make me smirk for some reason!) which has has some green paint applied plus some of the green foliage material attached.
Finally, over all the grassy areas a liberal sprinkling of dried herbs form the kitchen adds realistic looking leaf litter and builds up a very convincing impression of clutter and mess.
This was my first "proper" attempt at a natural landscape (I don't count the base of the 1:32 Spitfire, that is just static grass) and about halfway through I was in a panic as it really didn't look at all convincing. However, perseverance and dried herbs made a big difference!
There is a lot of diluted white glue involved, either from a spray (not always so good when there are lots of small loose bits) or from a small syringe. So much dilute glue that the base board got saturated and came close to sagging, so some support has had to be added underneath while it dries.
Finally an idea of the scale and appearance when the Tilly is added...
That's looking rather good Andrew. Cant beat a bit of dried herbs to liven things up a bit.......That sounds sooooo wrong LOL
Another update... almost there...
So things are moving along now...
Next task was the ground on the other side of the hedge. This was pretty straightforward with glue, flock grasses, twigs, herbs and so on. The emphasis was on making it look convincing.
View attachment 27235View attachment 27237View attachment 27236
So apart from some minor tweaking of the hedge and gravel path, the diorama base is finished. All that remains is to pose the Tilly and add the cargo. Watch this space...
