Further to the CA and baking soda - I have used CA and talcum powder - it's allegedly finer than baking soda! - No idea if that's true, but it works.....................
Thanks Dave, another one to ponder.
it is
used it many times......bonus is that it dries rock hard quickly but sands easily
Cheers Paul.
as already said,I have done it alot with,these,s vinyl kits,is superglue and baking power,
as a filler,just leave a 1mm or so under,and fill the rest with,on of the other fill,s if you like,:smiling::thumb2:
Monica thanks you, great tip with leaving it under filled.:thumb2:
I've used all of the teqhniques depending on the size of the gap. My preferred is CA Glue and milliput/Magic Sculpt
Peter
Morning Peter, think I have some Milliput. oh the choices:smiling: .
Hi John
I have only done anything like you mention a couple of times so I'm definitely no way experienced. The idea is not mine but taken from a YouTube video.
Take a stiffish piece of wire. Drill a hole into the ends to be joined. Say the shoulder and the top of the arm. The join does not need to be close fitting. Fix a short length of wire into the two holes with CA. The wire allows the arm to be bent into the desired position. Milliput or similar can be used to fill the space around the wire. The putty can be sculpted to match the surrounding area. The putty cures and sets the limb firmly on place. I use a VERY thin smear of Vaseline to stop the putty sticking to the sculpting tools and to smooth it. Before painting the Vaseline is cleaned with lighter fluid so the paint sticks ok.
Hope that makes some kind of sense.
Jim, as soon as I read the use of a flammable item,:smiling: , thanks for the tip , no doubt I would have missed that and ended up with a botched paint job.
I Agree with Peter on the small chips used as filler. then baking powder and super glue like Stillp and Dave suggested .
Rick
Thanks Rick. John.
Thank you one and all for the suggestions, so many to choose from , I shall go off now and have a play, of course explaining to Management as to why I have stolen her talc may be rather awkward, it was bad enough last week asking for some hair spray. !!!!
With luck I should post an update on the build page.
John.
