Thought I would share a couple of tips that were well used 20 years ago when I first got into modeling..
A quick way to paint the outside frame of a canopy.... Get a gloss sheet of thick paper or glass. Ive found A4 gloss card to be perfect.
Using a large brush, take a generous helping of the required paint (un-thinned) and paint a 10p piece sized circle of paint. Holding the canopy tightly
dip the edge you want painted into the paint and gently rock it a few degrees. Let dry then repeat for other edges. With a little practice its possible to get
as good an edge as you would get masking.
A quick way to paint inside frames of a canopy.... My grandfather was a user of this method. Take a craft knife and dip the blade side in your circle of paint (See above)
Quickly hold it on the canopy frame line and rock it from side to side a few times. Lift the blade off and you will have a straight line of equal thickness.
Why not try using both methods to complete a canopy....with a little practice you can do a canopy in minutes without the time needed to mask or to paint free hand.
Hope this is helpful
Danny
Danny
