Bigfoot57
- Joined
- Jun 24, 2015
- Messages
- 1,230
- Location
- Weston Super Mare
- First Name
- Colin
- Location
- Originally a small village outside of Reading Berkshire called Burghfield Common
Well its finished sorted out the tracks and the wing mirrors hope I’ve done you Chieftain supporters justice in my efforts on this buildHere’s what I liked & disliked and there’s a decal mistake on behalf of Meng as well
So I liked the following instructions clear and precise along with colour call outs when needed the type of plastic minimal clean up required the fit of the parts most are keyed si they only fit one way the track construction jig
Dislikes Tracks too tight on jig after the plastic pins have been inserted most snap off due to the force required to remove them from the jig in a lot of places i used.6mm brass rod
The PE despite etching was reluctant to stick with any sort of CA glue the Turret Baskets in particular were a right pia
Decals one was printed totally wrong see if you can spot it
