Chieftain Mk5 (Tamiya 1/35)
OOB Pete, who are you trying to kid. With the Haynes manual at your disposal. :tongue-out3::smiling2::smiling2:
It's only the cover of the book the pages are all blank ;) honest gov.
Pete.
Don’t think I’ve ever seen one of these being built so interesting to see what it’s like.
I’m sure you’ll do it justice :thumb2:
Hi Pete - I recently got one of these and the Haynes. If I ever get around to it the plan is to do it as a dilapidated range target
Bought some worn track links for it - metal links with individual pock marked rubber pads
Welcome on board Si, I hope I can do it justice to so fingers crossed.
Pete.
How that is somehing different, hope I get to see it one day so.
Pete.
Come on then, stop nattering - get building - where's the tea and cake and next time can you put out softer chairs.....
Mike.
Mike.
Hi mate you know I'm from down south it is a chaise lounge not a lounging pit sorry sofa.
Pete.
Hi got the Horstmann suspension units, sprocket, idler, road wheels and skirting plates bracket all made up and fitted.
Drilled out road wheel drain holes.
Drilled out hub caps drain holes you can also see the road wheel drain holes .
Thank you for stopping by and all the parts did come OOB ;) .
Pete.
