Chipping solution
Once chipping solution is applied and then painted over, how long can it be left for before doing the chipping.
For example could I chip away the following daybor a week later.
Typically not that long. Normally it quite a quick process.
Apply base colour - let it dry
Brush on / spray on chipping medium - let it dry (check instructions)
Spray top colour - let it dry (15min - 30min)
Then start chipping process.
Seal with suitable medium.
Apply wash.
Seal again.
Fairly straight forward.
Do you guys mind If I join in please ?
Gavin is quite right, the only thing I would add is the longer you leave it the harder it is too remove, as I know only too well:hugging-face:
