what can I use to clean the airbrush after using Klear ?
Try using spirits or cellulose thinners if you are fining serious problems although stay away from the cellulose ones if you have a chinese copy AB also concerning clear, I use the humbrol 125 mL version and it has better value for maney and is a great gloss medium.\ said:Steve why use Klear indeed when there is a better product. Obviously my opinion.Humbrol "Clear" designed for the job applies well with brush and airbrush. Good varnish and base for decals. Plus it is more robust than Klear. Plus it does not cost £15, it varies, a bottle.
Plus cleans up well with products designed for the purpose just like any other model making paint varnish.
QED.
