Comet-ed
Andy T
Well-known member
This all started when I ordered a new Tamiya Comet from John at the shop. Don't ask me how but I managed to add it to my basket twice so ended up with a pair of them :upside:
Pretty soon I got the idea for a little scene so got hold of these guys too
The story goes that our brace of Comets happened upon a rickety looking wooden bridge and one of them decided to have a go at crossing, with disastrous results. So we'll have a stuck tank, a collapsed bridge, another tank trying to tow it out, and a few guys lolling around watching the fun.
I may even add another vehicle or so to spice things up if I find something suitable but I still haven't got a full plan in my head. However, after some consultation with Mr Race I have an idea of where to get started (thanks again John) and I have a couple of pictures for inspiration, so will see what develops in my head as I build the two tanks.
First job was to get cracking on the tanks. Being a very newly released Tamiya kit I expect that part to be easy peasy, but to make painting easier later on I started with an idea developed from something I once discussed with the late great Simon T. He would glue a nut or use a rivnut on the base of an AFV to take a bolt which could then be used for mounting somewhere. Taking that a step further I've put some 1/4-20 brass inserts, made for the 3d printing lot, into the base of each tank. These have the same thread as most photographic equipment so I can bolt them to my mini tripod and paint/weather from all angles :nerd:
(more glue was added after these pictures)
Not much longer after that we have a good chunk of the lower hull together. At first some of the parts looked like they weren't going to fit :surprised: but it turned out the clearances were just so fine that a little "click" was needed to get everything into place and fitting perfectly. Marvellous engineering.
That's all for now but this may be a long one (by my standards) so please bear with me.
Sounds like a plan Andy. I like the collapsed bridge idea. Will it be over water? I remember Simon T and his glued on nut. One of his many good ideas. The tank kits sound typical Tamiya so should allow you to get on the the base pretty quickly.
There'll be a little water Jim but the pictures I have show more like a large ditch, about 2 tank lengths wide, so it won't be a large expanse.
As usual the Tamiya kits are a bit lacking in fine detail but go together really well. I've looked at pe and even a fantastic resin upgrade kit but that isn't really my style, and with 2 to buy it would be a bit spendy, so they'll be pretty much oob.
Andy with all that happening I don't think you need to worry about any upgrades, it's not as if it's a stand alone model .
Will follow from the front row , tea would be nice and a bicy please.
Good to have you John. The wife's RA is responding well to treatment so she may be able to knock up a batch of buns for the VIP's
It also lifts it to a more comfortable working height for me Pete. Better than balancing it on a stack of boxes!
Oh,a Comet :)
This is on my wish list,and the exact same Tamiya kit too,needless to say that I'm in and shall be picking up tips from the sidelines ;)
Thanks Ian.
I don't know about you picking up tips Andy but I've already noticed a few places where I'll need to ignore the instructions or I'd have to paint it in one solid lump, wheels, tracks & all!
Thanks Andrea.
I was going to title the build "The tale of two Comets" but it's a bit close to that of Steve/Stona's
Cheers Paul, it came in handy for this bit too.
This afternoon was wheels & tracks. It's a job I despise and I'd probably build more tanks if it wasn't for this stage, but there we go. I was really pleased to get it out of the way but then realised I've got it all to do again on the other one :worried: I don't know how others approach link & length tracks, but since I took pictures I might as well share how I do them.
After the wheels & rollers were built I cemented them to the suspension with the merest dab of TET, just enough to hold them in place. Note how one of the return rollers has an alignment pin to make it impossible to get the tracks in the wrong place & direction.
Tamiya provide a template for laying the track pieces out but in the past I found it hard to build them on their sides like that, and it left room for user error, so instead I put the pieces in order on a strip of masking tape and lightly cemented the joints. 19 pieces here.
After a few minutes, once the glue had started to take effect but was still pliable, I wrapped the lot around the wheels, adding the lower section too. Once it was all in place I went round the outer edges of each joint with more cement, taking care not to stick the links to any wheels.
I left this for half an hour while I went and had something to eat (chicken fajita wraps washed down with a fruity little red. Yummy )
The tracks had hardened up by this time so I carefully removed them. The minimal cement on the wheels meant I could just rotate them to crack 'em free, and everything slid off nicely. I then went around the track joints once again with TET and will leave the tape on overnight.
I'll then be left with everything in separate pieces which should help with the painting. I'll no doubt add a bit of damage to the rubber tyres before I get to that stage.
I'm probably teaching many of you to suck eggs, but if my method helps just one person out it'll be worth the typing.
Firstly Andy, you have to love a Comet!!
Even it was essentially a Cromwell on steroids, it nonetheless looks the business and something that has hints of a modern MBT. I've always had a soft spot for these ever since I had a couple of Matchbox ones as a kid.
Secondly, I can only commend you on your restraint. I have heard good things about these Tamiya kits, so I think you did well on not succumbing to more!!
I on the other hand suffered catastrophic shopping cart issues a couple of years ago, when Vespid bought out their VERY highly rated 1/72 Comet. This was the first Braille scale Comet since the Matchbox ones and so I ordered one from John or so I thought........
..........when I opened the box there were four inside......that's right......FOUR......you could hear the credit card complaining.......but absolutely NO idea how it happened....NONE whatsoever! :surprised::surprised:;)
Will try to drop in between my study sessions!
Good luck with the build.
ATB.
Four!
Now that would make a really interesting diorama... :thinking:
:tears-of-joy:
I don't build tanks, but if I ever did - this is ingenious!
Always a good feeling to get the tracks made up and know they fit.
Shame I have another set to do on the next one.
Cheers Paul, I try and avoid them when I can.
I don't mind sanding 4, 6, or 8 wheels but 40 is a bit much lol. Some have many more!
