I have an AS186 compressor, the generic tanked one that lots of people re-brand. Got it from ebay about 6 months ago.
Last couple of days it's developed a fault whereby it will start and run fine, but once it's hit pressure and shut off, it won't always start back up. At first I thought pressure switch but the motor is actually humming so it must be getting the signal to fire up, it just won't spin over.
I've had this on other compressors when they've got too hot and expansion has seized the pump a bit so the motor hasn't got the power to get it initially going, but I'm not sure that's the problem here as sometimes it has only run for a few minutes, with a large desk fan pointed at it, so is still pretty cool. If I leave it switched off long enough it will fire back up when powered on though, so it has me baffled.
Has anyone had or heard of a similar issue, or can maybe shed some light on it for me?
Andy
Andy
