For this tutorial I wanted to make a nice big blast hall into a cylon raider and show some internal wiring damage. I used a soldering iron and controlled the temperature to create a hole into the outer wing of the cylon raider. After the hole was created and looked decent I then took some grounding braid and cut it with a large pair of metal scissors so the edges were frayed.
Grounding braid is used in some electronic panels can be easily purchased through Amazon.
I then glued that piece from the inside of the cylon raider so the wire stuck out through the battle damage hole created by the soldering iron.
The effect was very real and showed that the damage through the outer shell then created some electric damage.
