Thanks Peter work in progress! Further updates tonight thanks for looking cheers DannyFantastic Danny. My head's reeling - so much to look at.
Peter.
Peter.
This diorama is nothing but one of the best I've seen sir !
MIND BLOWN.... DAAAAAAMN that is superb... well done Daniel
Wonderful Daniel! Could you put some tyre tracks, etc. on to make it even better?
Where will you display it? I see you have a huge case for it. How big is it?
HI Daniel two questions if I may, your ground cover can you please tell me what you have used and did you make your palm trees ?
Absolutely stunning :thumb2: there's only one thing wrong with it-------------- it's not mine :loudly-crying::loudly-crying::loudly-
crying::smiling::smiling::smiling:.
Pete.
Just a quick thought about the tyre tracks. Try experimenting with beads of PVA to fix parallel lines of sand either side where the tyres have been.Hi Andrew thanks for your advice! I had the tyre tracks in mind as well! I tried but the sand is rock solid! If you could give me any idea or a good way to create that would be great! Please let me know if you can assist! Thanks regards Danny
Thanks for the advice i tryJust a quick thought about the tyre tracks. Try experimenting with beads of PVA to fix parallel lines of sand either side where the tyres have been.
