The only problems I see with this method are that it leaves part-discs where the dark yellow patches are and produces some discs in two colours, both of which are obvious in the lower photo. If the real thing was sprayed through stencils with circular cut-outs, then there wouldn’t be soft edges to any of the discs unless the painter didn’t fill the stencil entirely with paint — and though I’m sure that might have happened occasionally, I doubt it would create a continuous line through multiple discs next to each other.In addition to what Mr. Jones has already stated, the most accurate representation of the factory disc camo scheme I have seen to date was done in AFV Modeler issue 16, 2004. (for reference only) where the factory 3 color scheme is applied and when dry the stencil with not the discs but the spaces in between cut out in a self repeating pattern and when applied over the top of the 3 color scheme was over sprayed with the base yellow to create the multi colored discs.
