Decals - after care?
Hello
Can I please soumd you out regarding decals? Having just finished applying a whole host of decals to my Sopwith Pup, using Revell Decal Softener, it crossed my mind, as it always does, as to whether or not I should be applying a coat of anything on top of the finished model. I have already applied flat varnish to the whole assembly before applying the decals but, of course, the decals are vulnerable.
Any advice is, as always, appreciated.
Kind regards
Aidan
After applying decals i always seal them in with a coat of 'varnish' which in my case is Klear
Hi aidan , most people usually give the model a coat of gloss before applying decals (the smooth surface helps avoid the silvering effect caused by tiny bubbles getting trapped in the rough surface of a matt paint finish) , then when the decals are fully dry a final coat of matt, or whatever finish is required , seals the decals in. Are you going to get us a few pics of the pup? cheers tony
Many thanks to everyone for their input which is much appreciated. If the work is up to scratch on completion, I shall post some pics.
Kind regards
Aidan
