\ said:
Ah right thanks dave, so I will need a setting solution too. I was hoping that the decal soft removed the need to use the gloss varnish before applying the decal. think I read that somewhere, what do you think?
First of all welcome aboard!
To answer that question, you may or may not get away with it.
Essentially the dreaded silvering, where the decal carrier film becomes visible, is caused by microscopic air bubbles under the decal. There is a much higher likelihood of this occurring on a rough, matt, surface than on a smoother gloss one.
Your decal soft is a solution which will soften the decal film allowing the decal to conform more closely to the surface of the model, hopefully to get that painted on look we all want. There is no guarantee that it will prevent silvering. You might be able to mitigate silvering by piercing a decal with a needle or the end of a scalpel blade and flooding it with a decal solution, but again, there is no guarantee. It's far better to get it right initially and that's why I always recommend a gloss coat of your choice. It's only one more step in the process and the final desired finish can be achieved with a final coat of a suitable varnish.
@dave.
I use the Microset/Microsol system myself. It's the blue bottle (MICROSET) which should be brushed onto the model. A dilute solution of white vinegar will serve the same purpose of softening the decal film slightly. The red bottle (MICROSOL) is the one that should be applied later and is a stronger solvent. It's one, or several, applications of this which will get that decal snuggled down.
Two words of caution.
First, although Microsol is not the strongest solution available it can be too much for some decals. I always test on an unwanted decal from any decal sheet to make sure it won't destroy the ones I intend to use on the model. If there is a problem you can always dilute the solution with water. I'd recommend this no matter which of the decal solutions you are using. This is a lesson I learnt the hard way!
Second, the blue Microset bottle looks a LOT like the bottle that the Liquid Decal Film comes in. You do not want to splosh this on your model instead of Microset unless you really want to start painting again! Another lesson learnt the hard way!
