Dragon 1/72 SH-3D "Helo 66" retrieving Apollo CM.
Stefee
Hemel Hempstead
Hi all,
Not sure if this is in the correct section as it includes a space craft and a diorama - mods please move as you see fit.
Just started this build and it's taking me way out of my comfort zone of building cars. Hope you think a build log will be of interest. Will be depicting the recovery of Columbia CM from Apollo 11. 66 was deployed from USS Hornet approximately 13 miles away.
This will be my helicopter, first diorama, first time working with figures and the first build where the interior and glass is fitted and painted prior to painting the body/ fuselage.
I have to do lots of research regarding colours etc. but I have a couple of, potentially many more to come, questions for the assembled experts;
1. The box art shows the main landing gear retracted but the instructions show it deployed - which is correct?
2. 3 sets of main rotor blades are supplied, folded, extended static on ground (drooping downwards) and in flight (curved upwards) - is the latter correct?
3. Would the exterior finish be gloss, matt, or semi sheen bearing in mind that the eyes of millions of TV viewers worldwide are watching the return of probably the most significant event in modern history?
4. The raft, flotation ring and flotation balloons are moulded in a rubbery type substance - how does one prime and paint these successfully?
Any and all answers and comments most graciously received.
Here are some photos.
Great iconic model set. The undercarriage was retracted when in flight. As regards the rotor blades, if your displaying it in flight you would not see the blades as they are rotating at speed so you would need to make up something that resembles a spinning rota. As regards rubber. Yes you can paint rubber. Clean the rubber parts first then apply primer and paint. If you can find a flex type primer and paint it will help. Also keep the paint as thin as possible to reduce risk of cracking, spraying would be better than brush painting.
Click image for larger version  Name:	40.jpg Views:	0 Size:	179.0 KB ID:	1257650
filedata/fetch?id=1257650&d=1747206895
Thanks for the very useful information Steve. Not sure if my skill set would enable me to simulate rotating blades but I will give it a go somehow, after all if it looks rubbish I can just revert to the kit blades. Regarding painting the rubber parts when I was a car painter we had a flexible additive for rubber spoilers trim etc. - Will have to do some investigating.
A little more progress.
Drilled hole and epoxyed a support tube (end of a biro) in the rear of the fuselage conveniently hidden by a bulkhead and placed support rod in seascape, looks OK and strong enough however would you wingy thing experts out there advise me putting some liquid gravity in the void behind the rod support to counteract the additional weight to be added up front?
Primerwd the interior and the colour looks close enough to be cleared and detailed.
Thanks for looking.
Great work Stefan. If your support rod is a good tight fit I wouldn't have thought weight in the tail would be needed. If in doubt put some in while you can.
Thank you. I think I will put a little weight in a small plastic bag in the rear as a slight tail down attitude will look quite natural.
As a first for me I have found that painting the seats , instrument panels and figures in 1/72 very difficult. Having only one fully functioning eye means my depth perception is totally out of whack so always put paint in the wrong place hence the somewhat amateurish attempts. All colours etc. mainly guess work and , as never having done a military model, I mixed colours using what I have. Will clearcoat tomorrow and do light washes.
Thanks for looking in.
Great effort Stefan. Everything looks good from here. I have to say that I try and avoid 1/72 stuff now and avoid pilots because I find them very difficult to paint. You've done a great job on those air crew.
