You haven't seen the other side!!!\ said:Very nice work indeed John, I think the pigment work and weathering are top notch
As far as wheel alignment is concerned, I can't notice any disparities. Remember when tanks are in the field they slop about in the muck and mire so you can't really go wrong
when dirtying them up. I myself being of the "work with what you got" type, find that actual "dirt" mixed with some white glue and thinned with a bit of water and slapped about looks quite convincing once dry and is after all "Au-natural" As far as "fixing Pigments" (whatever you use) "Testors Dull Coat" (spray) works great and seals and dries to a nice flat finish.
hope this helps a bit. Sometimes I even give a hint of a spray with a "satin" finish clear coat as this helps to highlight edges when taking pix.......Cheers...Jim![]()
Thanks for the comments Monica! That video makes for interesting viewing - it becomes clear that, whilst Dragon unarguably make great kits, they seem to take a lot of short-cuts to avoid re-making parts that, to be honest, need re-tooling. You have to remember that my good lady paid £59 (about $85 Aus) for this kit. Fine, if it was what was reviewed by Perth Military Modelling, but it wasn't . Dragon change the specs as, and when they choose. Frustrating when it didn't even come with engine grille PE\ said:great looking early big cat John,,do like what and how your done it,
real like you dust/mud effect,and very suitable weathering,well done,
thanks for showing the vid as well very interesting in what he i say,
will be going back to that,
Thank you Brett, as it happens, and by no coincidence, I too am building the same Sherman, it's the one we spoke about a while back, and is such a good kit. I spent hours today, with radio 3 on (BBC classical station) and was in building heaven! Painting is my main love, but a new-tool tamiya is always a real joy to put together (my recent Matilda was also awesome). I hope you enjoy the pigments, do wear a mask, they are easy to inhale, and don't be afraid to mix them as you would paint, it works beautifully, and gives a real range to play with!\ said:That is a very nice Tiger, John.
I really like the color since one doesn't see the grey used on Tigers much, and that particular batch of vehicles with the turret-side storage bins is really cool. Your weathering is very good, in my opinion.
And funny you mention the Sherman... that is the kit I will be starting next. It will also be my first use of pigments. I recently got a set and am champing at the bit to try them out.
Thanks Robert!\ said:I agree with all comments made on here John. This looks a very nice tiger and the weathering looks spot on ( from what little I know on tigers )
Really grand work on this
Regards
Robert
You ought to build it then, as, for the most part, it is a straightforward build, and I'm sure a more experienced modeller than me wouldn't have fallen headlong into that wheel alignment trap! It is pricey though, very pricey compare with the new tool Sherman I've just started, which is the equal, and superior, in some aspects, to the Dragon beast, and nearly 45% cheaper!\ said:Nice work, one of my favorite tigers with its double bins. I've yet to build this beast.
