Morning all.
I decided it was time I used my machines to build something other than tooling, so I've chosen this as my first engine build. This is a model of a simple steam (or in my case air) powered engine designed my Elmer Verberg. This is a relatively cheap build, there are no castings, it's all built from bar stock so only around £30 in metal (although in fairness several thousand in tooling).
The plans and stock.
I'm starting with the foot and frame, these were rough cut from 10x50mm aluminium then squared up.
And the features formed.
The most nerve racking part of this was the long 3mm hole from the end all the way down to the crank pin hole, around 60mm.
