After reading the advice I have ordered the mixer it should arrive Tuesday .Good job its only small I am running out of room to put things
I cant quite picture the gap, and am not sure how you attache the top to the bottom hull and how much give you have in the top hull, but 2mm doesn't sound like much. I prefer to fill gaps if at all possible rater than remove material and how it all lines up\ said:With the WTC sealed and the electics in place decide to fit the top again and oops it will not fit bow and aft. It is rased approx 2 mm so i presume if i file 2 mm of the ceneter section all will be well.
