Hi Folks,
As the title alludes to; this is a figure bust built from scratch. Sculpted and built from epoxy resin (Green Stuff entirely) with only a few basic tools. This was done on a whim because I wanted a new challenge. It's a German WW2 soldier, I would estimate the scale at 1/9 -1/10. This was done with virtually no video aids or anything like that, I just went for it,
the only hint I took on board was using a copper wire armature as a base to build/form the resin.
It may not look 100% accurate but I'm fairly satisfied with the result. The hardest part was sculpting the helmet! Again it's not a carbon copy but hopefully you can discern what it's supposed to be!
Hope you all enjoy it and I welcome feedback.
the only hint I took on board was using a copper wire armature as a base to build/form the resin.It may not look 100% accurate but I'm fairly satisfied with the result. The hardest part was sculpting the helmet! Again it's not a carbon copy but hopefully you can discern what it's supposed to be!
