First photo etch attempt
coachman
Decided to use PE on my latest model,109 G6. I studied the instructions
to familiarise myself with the parts and their fitting,one piece has me
bamboozled,(not difficult). There is a small piece of film,on it, it gives
part No. and model to be used on,above lettering are 4 for want of a
better description,windows,one end is arch shaped. I can't find this piece
anywhere on the fitting instructions, I took a look at the dashboard fittings
no sign of it. On the view of the gunsight there is shown a part that is
marked up, foil, this on an exploded view. This is the only part that looks
anything like a piece of film but there is no part No.with it,and there is no
foil in the etch kit. The film is much bigger than the gunsight,unless you're
supposed to cut one "window" out. Hope you understand my ramblings
and are able to help. Thanks John
Hi John,which kit/scale are you building? It sounds like a Hasegawa.It's a Bf109 so i might have made one! I'm a bit confused by your description,any chance of a photo?
I'm trying to think of why something would be marked "foil" on the Revi (16b from memory) gunsight.
Hi Steve,your right it's a Hasegawa Hartmann kit 109 G6/14 1/48 scale. Looking at your picture
which has a squared off arch appearance,looks to be going in the right direction. Afraid I've
never uploaded pics. the PE set is Eduard 49211 the film is marked FE211 I don't wish to
impose on your time, but if you have the chance to look it up I'm sure it's shown on the
set details,don't understand why it isn't mentioned on instructions.Thanks a lot John.
I seem to have spent most of today trying to upload photos. I've managed to get them in members gallery,can't get them into the post. Hope Steve or someone can help. Please take into account the fact that I started work a week before I was 15 and the nearest I got to technology was 2 speed axles and splitter gearboxes. Just an old Numpty! Thanks, John.
I've got your piccies. I'm sure this is all part of the gunsight. I've never used that set and am just trying to figure out what goes where! I'm going to phone a friend.
Looking at those photos John, the foil, the one with the 'windows' on is the glass for the gun sight, you just need to cut one out. Nice of them to give you four, they are a bugger to cut out!
You need to cut off the plastic one from the kit part N1, then fold the PE part nr 9 as shown. Glue that in place, paint it then glue the 'window': the HUD glass in place.
Hope that helps.
Thanks Steve, I shall have to learn how to put pictures with posts,and many thanks
to Ian, your description I fully understand.I thought it was the most obvious solution
but it would have been clear if if they had said film instead of foil or at least put part No.
on instructions. Thanks again, your both top of my christmas card list. John
