Hi Tess
I've done exactly what you're attempting with the Revell 1/48 Memphis Belle B17. I didn't use airfix motors as they proved a bit too large for the engine nacelles but providing they fit in the B29 it will be fine.
Essentially what you do is wire a series circuit, to do this:
1. Run a twin wire up through the tail wheel opening and along the fuselage to the wings
2. Split the wire here and run one end to the furthest engine on the left and one to the furthest engine on the right. Do this before joining the fuselage halves and the wing halves and after the engines have been securely mounted in the wing bottom halves. Ensure the engines are mounted correctly and are true or the props will fowl against the nacelle sides.
3. Daisy chain the engines on the left and then pass a wire through the fuselage to daisy chain the engines on the right (see diagram)
4. Glue the wing halves together, then glue the fuselage (do this on a wide flat area as the connecting wires will mean plenty of things to support!)
5. Glue the wings to the fuselage feeding in the wire slack into the fuselage as you go (ensure nothing is snagged).
6. Connect the 2 wires at the tail wheel end to a battery and your Super Fortress should spark into life!
Things to note:
1. Solder all the joints
2. Expose as little bare wire as possible to get the job done - this will cut down the risk of a short circuit
3. ensure the engines are mounted properly centred through the prop shafts
Have fun with the B29 and good luck!
Paul
Ps. Sorry, I forgot to mention I mounted the engines first pressed into putty to get the alignment correct. Once hardened secured the lot with epoxy resin (ensuring non of this goo went into the engines themselves which would obviously prevent them from working).
