And elevators.
I've been playing around with detailing my 1:72 Airfix Hurricane, (this is an early Airfix kit and very simplistic and have already had to add detail to the cockpit as I plan to model the canopy open).
The main reason being this is a cheap kit and therefore an ideal testing ground before trying it on a pricier kit.
One of the niggles I always have with models of planes which use cable / pushrod mechanical control surface operation is the fact that the kits are modelled with fixed straight elevators and ailerons when typically elevators on the tailplane will naturally sag when the aircraft is stationary on the ground.
I wanted this model to also have it's flaps open as if it had just recently landed.
To model these i used a scalpel to gradually slice through the flaps on the wing underside and the elevators on the tailplane, a quick dress of the edges then I drilled the tailplane and elevators with a small drill in a pin vice in two corresponding places.
The elevators were then joined using small sections of staple, (small enough but stiff enough) held in place with a dot of superglue, then bent to a visually acceptable deflection and a smear of liquid poly cement brushed on to secure it.
The flaps couldn't be done the same way as they were much thinner so I placed them using small rolls of masking tape as wedges then brushing with a smear of liquid poly cement. The flaps should have strengthening ribs internally but that's just beyond me at the moment.
I was quite pleased with the overall effect and hope this will be useful for anyone else wanting to model open control surfaces.
View attachment 15765View attachment 15766View attachment 15767View attachment 15768
