Thanks Moni I appreciate that also thanks for the tip I do have some course turf in a lighter colour and I was going to sprinkle that on with my fingers but the coffee jar idea sounds much better\ said:that is a very nice tree Alan, starting to take shape , and like how you have use a real bit off stick,if you are finding that the PVA takes a bit to long to set,as I did, use UHU drys quicker and dose dry clean, and can be painted over, once you find that there is all the foliage you like then use the hairstick to
add darker on the underside and lite on the top ,just sprinkle buy your fingers or use a shaker, what i did was make one from a coffee jar the big one and drill
No 30 hole very close together, to shake out the foliage
must say Patrick that the branches on your Jagdpanther. worked out very well with mixed herds great job
Cheers Moni I've started on the Marder and it's the first time I've painted the camo I just hope I'm doing it right View attachment 80171\ said:both nice kits Alan ,
Cheers Moni I appreciate that\ said:well done ,I real like itdid you do that camo with a brush or a sponge ? as it has mottled edges,I would say it would as if its in the same unite with the same commander
Yeah pretty much but wipe most of the paint off not as much as dry brushing through\ said:hi, Alan, so just push the cut down brush , and it gives the molted look,it turned out so well,great tip Dave has given,
