Gloss Acrylic Varnish?
Hi David. I use Vallejo satin polyurethene/acrylic.
Very forgiving self levelling if you over do it a bit. Just one coat. 20PSI & keep the brush moving.
I start one side with a lightish coat then the other then first with a full coat. Finished in one.
Thanks Laurie as I said I had a bottle and would let the boys know what I thought ,çouldnt belive how low the pressure was and in the end how far from the model I got still its all a learning curve and at the end of the day its only a peice of plastic (I know lovingly crafted then ruined )but no one was hurt except your own expectations.
A lot of the chaps have mentioned the VMS varnish watched a video on YouTube christ the bloke lashed it on like you'd never belive but the end result was impressive. Once again thanks for your thoughts every little helps said the woman as she p'd in the sea ,it all helps stay safe. Dave.
Thanks for all the replies - I'm got a bottle of the Mig Lucky Gloss Varnish - although I'm not planning anything with a gloss finish for a while.................
