what could be causing glue not to set ?
I know things like environment,heat,cold,grease,ect can effect these things but these Ive had to rule out as the plastic is always cleaned by myself and we haven't had any hot or cold days for it to be a weather problem
Now here is the strange part , the last two aircraft I have built I've had a problem with the landing gear on the port side and it's the same problem exactly and I've had no problem anywhere else on either model or any model I've built in the last month so what could be happening here?
Why is it localised ie landing gear and why is it the same side ??
Baffled to say the least !
