GMC CCKW 353 "LeRoi" Truck w/Compressor
minitnkr
My attempt at the 1/87 scale Truck w/Compressor by Trident in white metal.
These are typical Trident instructions. Resin tires/wheels are from spares box as easier to use than supplied metal ones w/o axle holes. Picture also reveals hours of cleanup, straightening, & some polishing for first pass dry fit of major assemblies. Scales much better than adp-Models offering.
Saw this in the latest acquisitions thread. Looks like you've got it together ok. Resin wheels are a good call. I can imagine the time invested in this so far.
Drilling out the differentials for steel axles & mounting the suspensions so all touch the ground equally is a chore all who muck about w/metal kits are familiar.
I find that to be the case in most of the resin kits I've had to deal with. Following with interest. Curious to learn more about the adp shortcomings, as I have had excellent results with them so far. Keep it coming, looks like a nice clean assembly from this angle. :thumb2:
I probably overstated the shortcomings of adp-Models' CCW as it scales out slightly small and it doesn't represent the LeRoi version compressor truck. You won't notice it till you put them in a group of other manufacturers' (ROCO, Trident, Heiser, Miltary Scale, etc.)1/87 scale CCWs.
I'm using the adp compressor truck on the Quarry dio so the Trident one will go with an Engineer Co. HQ section & as a exemplar for updates to the scratched ones.
Blimy Paul looks like you've had to wrestle this one to the ground ,well done you only get back what you put in looking forward to it getting another coat of paint. Dave
For a metal kit, it has clean and crisp detail.....better than I expected. Looking forward to the finish up on this one Paul. :thumb2:
Progress. Needs jerry cans & some touch up to go.
Before cuppa.
Better pic.
You've done really well with this Paul. As Rick says there's far better detail than a lot of similar stuff I've seen.
Moved LeRoi project to here.
Some progress on shaping, more to do. Fuel & air tanks done. Still trying to figure out tool lockers.
