Going underground: "BMP in Aleppo ll"
Hello Chaps
*thanks for the comments - always appreciated
I am takng a break from the balconies (not on them…) for a moment to focus on other parts of the building’s details – the sandbagging.
Being heavily fortified, the building has fairly tall sandbag walls both inside and out. That’s a lot of sandbags and a lot of milliput…..so I reused a silicone mold to produce the bulk of the piles of sandbags from plaster. Mold was a leftover form making my 3 Great War– dios.
Further individually produced sandbags from Milliput will be added to these to add height and details and fill the void between it and the wall.
Base coated black and painted off - white these will be further weathered using pastels and wahes .
In Aleppo everything was used to make sandbags including pillow casing and duvets (I am told this was also the case in the first stages of the entrenching stage of Great War on the British side) - regardless of the designs and patters – I did include this on the first version of this dio but have omitted it here as I feel it would be lost to any onlooker.
On the LH corner upper balcony there’s no possibility of short – cutting as I plan to show that the near total destruction has caused the sandbag wall to partly collapse- this will be a challenge to do realistically.
Hello Chaps
Bit of an update on the destruction on the Balconies:
sandbagging, adding details such as rebar and smaller broken pieces – everything is WIP and there’s a lot to be done – I am hoping to finish the general work on the façade come end of February, I will however be taking a break from the Façade (to preserve my sanity..), to concentrate on smaller details on the building and the Roof covering the Arcade (sigh more electrics... )
Rabar can be a pain to work with but it does add some interest to broken Concrete – Cf. top and below where it still needs to be added. I will twist and mangel bend and bow these accordingly
Hello chaps I finally got time to post an update.
Leaving the building aside for at moment I am right now concentrating on doing some detailing of the Arch Arcade roof where I am planning toad a ceiling fan and a light fixture.
Pics
Construction of the fan using plastic strip and the head of a clothing pin and some fuse wire – it is not a masterpiece of accuracy but it does not need to be as not much of it will actually be showing
The lighting fixture is form Verlinden (although scratching one is easy, I chose the easy route...). I have added metal brackets because the original idea was to have it partially hanging from the roofing form a bent bracket. I have since abandoned that idea, in favor of having it fully torn from its mounting brackets and dangling from its cable alongside some other installations. Damaged will be added to Brackets accordingly.
All for now – thanks for watching.
Next time: some updates on the building – interior, rooms etc. and we will be adding some rubble and details to the balconies.
Pictures:
Mounted and weathered
Weathered:
Hello Gents
It has ben a while since my last update on the build. I am currently dealing with a spot of illness ( nothing major but did not further the process at all) which has caused a slowdown in the building process. I have had a month between jobs before I got sick which I tried to use to my advantage and here are the things I have been focusing on
The Bar/Restaurant :
Floor Tiled by laying individual tiles (silicone mould from Reality In scale) wash with brown acrylic washes
area near the edge will be covered in rubble
Amongst the rubble chairs and tables crockery and the like will be scattered
Speaking of chairs I will be using these from Mini Art they were an absolute pain to assemble and sand - I broke at least two legs per chair hope they will be worth the trouble...
I have added some vintage Arab movie posters to the wall to add some atmosphere and some 3-d mosaic tiles form Reality In scale.
DIY counter parts of which will be partly crushed by the debris from the ceiling - to do this realistically will be a challenge
Balconies
I have begun adding debris to the upper and lower balcony
I will add a dark wash to create or enhance shadows and add depth and will also play around with a bit of subtle variation in color using shades of gray. brown and buff alongside pastels.
Taking pics of the lower is a pain - wip
I was thinking of using Microscope slides for the glass but settled for a thin smartphone cover instead just a lot easier to work with - and safer.....
I guess that is all for today I will add some pics of further updates in the coming days thanks for watching
I love your way of working and attention to the tiniest detail!
Superb stuff.
Hoping the illness is behind you now?
Ditto, and I took note of the smartphone cover tip. :thumb2:
Superb modelling skills and attention to detail.
Keeps getting better & better.
Thank you so much for the nice comments - it helps keeping up morale and are welcomed when this thing just seems a never -ending project - as it does now.
Superb stuff.
thanks so much for asking - I suffered from bacterial Pneumonia for about 6 weeks and although fever free, up and about and returning to work - my respiratory system is still feeling the effects to some degree and will be for weeks to come.
Steven have to agree with Neil the detail is perfect, I esp like those Arabic posters.
Glad to read your getting better slowly, that illness sounds nasty, take care.
Thanks for all the kind comments Gents
Space is limited on the bar´s flor so to keep that in mind I have made a rough guide as to what will on it :
The lamp destined to lie amongst the rubble behind the counterr is this one from Royal Model ( no affilation) another one will still be hanging from the ceiling on the opposite side of the room...
More coffee cups have been added to the shelves alongside som vine glasses - I do admit to be taking some creative license here as in reality everything that was still stranding on the shelves would most likely have been thrown form them during the destruction of the building.
I will place crockery on the shelves and some shattered on the floor.
- decals are quite easy to apply an the result is quite convincing:
What`s a bar without wine- I plan to have these alongside a bottle of brandy scattered on the shelves or floor - or both. Although I hold an MA in middle Eastern history and societal conditions I still needed to check up on the Alcohol policies in Syria - which as it turn out are quite liberal given the secular nature of the Regime
All for now - time for a Pint and maybe some modelling :-)
A pledge....
Hello Chaps
small update as my bench time is quite limited these days, despite this fact i dare venture into putting forth a finishing deadline: December 2024 - there, I put forth a public pledge to finish this when we deck the Hollies..... - help me honor this :smiling: - It has just been going on for too long and the build is in its 4th year...
on to the build:
I have been adding bottle to the shelves a bottle of brandy is to follow
Lamp is lying amongst the rubble - wires will still need to be glued properly. and more rubble will be added to the scene once the building is fixed to the base.
- looking at the pictures I realize that I will have to move the lamp towards the fridge .
I´ve wallpapered the second floor Apartment using extra thin wallpaper from Reality in Scale - fiddley stuff that. When mounting I recommend using as little water/PVA glue as possible. The colors did bleed somewhat during the mounting but I can live with the result - most of the walls will be in shadow when the roof comes on and as I will have broken slabs of Concrete hanging down they will block most light coming into the room.
I have started adding rubble to the restaurant floor and added an overturned chair
Have a great Week
This is so good that no one dares to write anything! Great work Steven!
