SMS Bot
GreenStuffWorld 0.7mm Drill Bits x5
This GreenStuffWorld pack contains five 0.7mm drill bits for drilling, positioning and starting holes across a variety of hobby projects. Their small diameter makes them suited to detailed work where a 0.7mm hole is required, from miniature conversions and assembly to scale modelling and model railway projects.
Having five bits of the same size provides a useful supply for regular modelling work. Each bit has the same 0.7mm diameter, so the pack is focused on one specific drilling size rather than providing an assortment of different diameters.
These drill bits can be used for creating holes as well as positioning and starting holes during construction or conversion work. This makes them useful for tasks encountered when assembling or modifying miniatures and other hobby projects where small, accurately placed holes are needed.
The 0.7mm size also gives modellers a clearly defined option when selecting from different drills and drill bits. Rather than changing between several sizes within the pack, all five bits are supplied at the same diameter for repeated 0.7mm drilling work.
The drill bits are intended for use with a variety of materials encountered in hobby projects. Suitable applications include miniature conversions, miniature assembly, scale modelling, model railways and arts and crafts. This range of uses makes the pack suitable for both construction and modification tasks that require small holes.
For miniature conversions, the bits can be used where drilling forms part of changing or repositioning components. During miniature assembly, they can be used to position and start holes, while scale modelling and model railway projects offer further applications for precise 0.7mm drilling.
This GreenStuffWorld pack contains five drill bits, all in the same 0.7mm size. They are intended for drilling, positioning and starting holes, providing a dedicated set for hobby projects that require repeated work at this diameter.
The post GreenStuffWorld 0.7mm Drill Bits x5 appeared first on Scale Model Shop.
0.7mm drill bits for detailed hobby work
For modelling, miniatures and craft projects
