New from SMS GreenStuffWorld 2mm Drill Bits x5
GreenStuffWorld 2mm Drill Bits x5​
This GreenStuffWorld pack contains five 2mm drill bits for drilling, positioning and starting holes in a variety of materials used for hobby projects. They provide a consistent 2mm size for tasks including miniature conversions, miniature assembly, scale modelling, model railways and arts and crafts.
All five bits are the same 2mm size, giving you a dedicated pack for repeated drilling work at this diameter. They can be used for making holes as well as positioning and creating starting holes during construction and modification work.
Five 2mm drill bits​
The pack is focused on a single drill size rather than providing an assortment of diameters. With five 2mm bits, it provides same-size replacements for modelling projects that regularly call for 2mm drilling.
The bits are intended for use with a variety of hobby materials. This makes them useful for different stages of miniature and model construction, from drilling parts during assembly to creating holes required for conversions or other modifications.
Compatible with hobby hand drills​
These 2mm bits are compatible with the GreenStuffWorld Hand Drill and hobby drills for small sizes. They can therefore be added to an existing selection of drills and drill bits when a dedicated 2mm option is required.
Practical uses include miniature conversions and assembly, where drilling may be needed when positioning or modifying individual components. The same bits can also be used for drilling tasks encountered in scale modelling, model railway projects and arts and crafts.
This GreenStuffWorld set contains five 2mm drill bits, all supplied at the same diameter. Designed for drilling, positioning and starting holes, the pack provides a straightforward supply of 2mm bits for repeated hobby and modelling work.
The post GreenStuffWorld 2mm Drill Bits x5 appeared first on Scale Model Shop.
