SMS Bot
GreenStuffWorld Miniature Painting Handle
The GreenStuffWorld Miniature Painting Handle is designed to give you greater control, stability and freedom of movement while painting miniatures. Its grenade-shaped body combines a soft-touch grip with a low, balanced centre of gravity, providing a comfortable way to hold a model without handling the miniature itself while you work.
A fully rotating head lets you turn the miniature to reach different sides without repeatedly changing your grip. This is useful for both detailed display painting and working through larger groups of tabletop or wargaming miniatures.
The handle includes two interchangeable heads for different ways of securing your work. A quick spring-loaded clamping system provides one mounting method, while the interchangeable adapter allows reusable mounting putty to be used when appropriate.
This modular arrangement makes the handle suitable for tabletop miniatures, wargaming models, resin prints, scale-model parts and sub-assemblies. Changing the mounting head allows the same handle to be adapted to different painting jobs rather than being restricted to one method of holding the model.
The rotating head allows the model to be turned while it remains mounted, helping you approach different areas and painting angles while maintaining control of the handle. A detachable finger rest is also included, providing additional support when required during detailed work.
The soft-touch grip and low centre of gravity are designed to provide stability without adding unnecessary bulk. Together with the rotating head, these features make it easier to reposition the miniature as you move between different areas of the model.
A separate clip-on base is included for storing the handle safely between painting sessions. The handle can therefore remain supported when you put it down, rather than having to remove it from the miniature each time you stop working.
The GreenStuffWorld Miniature Painting Handle combines a rotating head, two interchangeable mounting systems, a detachable finger rest and clip-on storage base in one compact holder, providing a practical way to support and reposition miniatures, resin prints, model parts and sub-assemblies while painting.
The post GreenStuffWorld Miniature Painting Handle appeared first on Scale Model Shop.
Two interchangeable mounting options
Rotating head and detachable finger rest
