Not sure if people know about this, or if I've made it up.
Wanted to add a mud to a chassis, and was messing about a bit with some Revell weathering powders.
I ended up adding a little DecalFix to my powder blend to make a thin paste and I found that if I dabbed it over my model, held it for about 5 seconds in front of the fan heater to semi 'bake' it (I model in the spare room, gets chilly, no central heating) and then blast the excess off with a can of compressed air, it seems that you get a nice powdery coating that is held in place, and because of the compressed air you also get the detail through too.
I would expect you could also quite easily mix up some paint, DecalFix and some baking powder to make a similar paste, dry with a hairdryer and a quick blast of air with a straw. I've had good results with baking powder to create texture as I know many here have.
Hope this helps anyone
-Matt-
-Matt-
