So, the one time I forgot to put my compressor on the floor it fell off the workbench - fortuitously onto a reasonably soft landing (some carrier bags) but it snapped off the hose connection at the compressor. Have now replaced the hose and connected it back up and air does indeed come out of the airbrush and it does shut off when pressure is up to the right level.
My wonder is though whether it is pushing out as much pressure as it did before? I never tried to exceed it before dropping it but now no matter how far I turn the pressure dial I can't get it to go past 2bar using the 0.3mm gravity AB and around 1bar with the 0.35mm siphon one (it was one of those all-in kits) which uses a much narrower hose.
It is probable that people may reply saying that I oughtn't need to go higher than this in terms of pressure but I am more concerned that there's a leak somewhere? Do these max pressures sound right or should I be worried? I also thought that a siphon AB needs higher pressure to work effectively and 1bar doesn't seem that much.
It's this one by the way...
AIRBRUSH KIT + AIRBRUSH COMPRESSOR AIR BRUSH NEW ® on eBay (end time 07-Apr-11 14:46:33 BST)
Any help/advice appreciated.
