Covering models with Mylar type films.
Thanks Bulent,here are their covering instructions which help explain what type of material this is-
1. Apply a coat of dope first to the balsa where you want the mylar to stick. Paint all the way around the LE and TE to give plenty of gluing area. Let the dope dry for a few minutes.
2. Then rub a permanent glue stick along the perimeter of the flying surface. Elmer's, Avery Permanent, and Uhu are reliable brands. You can moisten the glue stick if it's too dry to give even coverage. Glue stick may also be applied with a damp artist brush, especially for confined areas or delicate structure. Use glue stick full strength on carbon rod structures (diluted glue stick doesn't have enough holding power to wrap around small radii).
3. Lay the mylar on top of the surface while at the same time pulling it taut. After it's on, keep pulling on the excess wherever you have wrinkles. You can usually adjust it a little if you lay it on lightly at first. Then burnish down and make sure it wraps all around the circumference of LE and TE in order to maximize gluing area. For flat structures, mylar may be taped to the building board (or held in place with magnets) and the structure laid on top. Let dry overnight.
4. For heat shrinking, use a very hot MonoKote iron or a heat gun. Do not touch the carbon rod with a hot iron.
Which type to use where
- For small balsa airplanes, 2um or 3um mylar is usually the best choice.
- For carbon rod flying surfaces or in those cases where more durability is desired, 4um or 5um is used.
- When using aluminized mylar, 2um usually shrinks more tightly and is easier to apply to compound curves than the 4um.
- 4um is recommended for use around window openings, windshield reveal molding or other detail applications, especially where it will not be heat shrunk. Small pieces such as trim strips are easier to handle if fabricated from 4um.
Painting
Clear mylar can be brush painted with ordinary model enamel, such as Testors, or equivalent. Tamiya enamel is recommended for transparent colors. Make a cartoon of the color scheme first and lay it under the mylar.
- Areas on the cartoon to be painted white should be shaded; otherwise it will be hard to see where you’ve painted.
- You need to be able to move the work surface to which the cartoon and mylar are taped. That way, you can turn the workpiece to a convenient angle as you paint.
Aluminized mylar is generally painted
in situ after application is complete. Apply rivets and panel separation lines prior to painting. For lettering or color separations that are not straight lines, make a paper stencil first. Trying to use tape or adhesive to hold the stencil in place is not recommended -- the mylar is too flimsy for that.
Use a Sanford® Sharpie™ ULTRA FINE permanent marker to draw color separation border lines. Sharpies are available in the following colors: black, red, blue, green, orange, violet, brown, yellow,
berry, turquoise, lime & aqua.
1. Hold the stencil in correct position and outline the area to be painted with a Sharpie pen that most closely matches the trim color. For straight lines, use a piece of scrap balsa or other flexible straight edge to guide the pen. Use dope thinner (acetone) to correct mistakes.
2. After the areas to be painted have been outlined, fill them in with enamel using a No. 2 sable artist brush (ModelMaster, Grumbacher or Floquil). Thin the paint if necessary to make sure it flows out. Begin at the pen line and work in, using plenty of overlapping brush strokes to ensure even coverage.
3. Then use a 3/8" flat artist brush for large areas. The enamel is slightly translucent so it’s important to apply the paint evenly (takes practice).
4. Corrosive and chemically reactive particles in dust can etch the aluminum and create clear spots. To prevent this problem, make a storage box for airplanes that are covered with aluminized mylar, or cover metal side in.
